Embedded Software Development
I am using the Zedboard. I want to send files or texts from my host PC to zedboard through the ethernet port. I am unable to understand how to do it. I have a standalone BSP and I have included LWIP in it. So in this case I am using raw API. Am I right? But how to interpret the file transferring application in it?
I have done the echo example and it works fine but in this case I am wiling to change the port number from 7 to a user defined one(>50000). So as per my understanding echo wont work in this port number as well as ftp. How am I supposed to do that? Will it work if I promptly change the port number in the given source code examples?
Any idea?
Oh yes. I have developed a file transfer application software where I can input the IP address of Zedboard and select a particular port and send the intended file. Can I put this to use?
You need a file system. Have a look at xapp1026 to see how to achieve this
Hey @stephenm  thanks for your advice. So I have gone through the document of XAPP1026. I just wanted to work with the raw apps part hence i copied just the raw_apps source codes into my file. But I am facing some problems. The header file, ip4_addr.h in the bsp shows the error "dereferencing pointer to incomplete type 'struct ip_addr'".  Can you tell me how can I remove it?
Can anyone help me? Any suggestion or advice will be helpful.
 Thanks and Regards.
Hello Tish,
I am having the same issue...did you figure it out? please advice
Murad
@jayyous  the problem is, I guess, the zynq SoC I am using is different from the one for which this XAPP source is written for. Hence, the hardware configurations are not matching exactly and hence, the problem persists. I could not solve it though.
Thanks Tish for the reply...actually, I am using the same hardware...everything was working with Vivado 2017.1 but when I updated to 2018.3, this issue occurred...will let you know if I find a solution
Murad
Hello Tish,
use:
ip_addr_t
instead of:
struct ip_addr
Murad
@jayyous  thanks mate for the help!
