chrisdowney
Error Starting XSDK (2018.3 & 2019.1)
Hi there,
I get an error message when starting SDK (both 2018.3 & 2019.1). The workspace selector appears and allows me choose my workspace but fails to launch with the error message attached to this post.
The contents of the log are as follows:
!SESSION Mon Apr 01 09:18:05 UTC 2019 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2019-04-01 09:18:05.798
!MESSAGE Could not find extension: com.xilinx.sdk.bundleconfig
!SESSION 2019-04-01 09:18:05.636 -----------------------------------------------
eclipse.buildId=2018.3
java.version=10.0.2
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2019-04-01 09:18:07.024
!MESSAGE Bundle com.xilinx.sdk.bundleconfig not found.
!ENTRY org.eclipse.ui 2 0 2019-04-01 09:18:18.273
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2019-04-01 09:18:18.273
!MESSAGE Commands should really have a category: plug-in='com.xilinx.sdk.appwiz', id='com.xilinx.sdk.app.commands.ChangeAtfBuiltReferences', categoryId='com.xilinx.sdk.app.commands.category'
!ENTRY org.eclipse.ui 2 0 2019-04-01 09:18:19.822
!SUBENTRY 1 org.eclipse.ui 2 0 2019-04-01 09:18:19.822
!ENTRY com.xilinx.sdk.utils 0 0 2019-04-01 09:18:22.659
!MESSAGE XSCT Command: [::hsi::utils::init_repo], Thread: Worker-0
!ENTRY org.eclipse.core.jobs 4 2 2019-04-01 09:18:22.734
!MESSAGE An internal error occurred during: "Initializing s/w repositories".
!STACK 0
java.lang.ExceptionInInitializerError
	at com.xilinx.sdk.sw.SwDbUtils.getReposMan(SwDbUtils.java:67)
	at com.xilinx.sdk.startup.InitSDK$8.run(InitSDK.java:365)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Caused by: java.lang.NullPointerException
	at com.xilinx.sdk.sw.internal.SwReposMan.<init>(SwReposMan.java:76)
	at com.xilinx.sdk.sw.SwDbUtils$SwReposManHolder.<clinit>(SwDbUtils.java:54)
	... 3 more
!ENTRY org.eclipse.ui.workbench 4 2 2019-04-01 09:18:43.765
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class com.xilinx.sdk.sw.SwDbUtils$SwReposManHolder
	at com.xilinx.sdk.startup.InitSDK$6.preShutdown(InitSDK.java:301)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:988)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
	at org.eclipse.ui.internal.Workbench.firePreShutdown(Workbench.java:985)
	at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1124)
	at org.eclipse.ui.internal.Workbench.access$22(Workbench.java:1112)
	at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1453)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1450)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1423)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1594)
	at org.eclipse.ui.internal.WorkbenchWindow.access$16(WorkbenchWindow.java:1540)
	at org.eclipse.ui.internal.WorkbenchWindow$11.run(WorkbenchWindow.java:1626)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1623)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1637)
	at org.eclipse.ui.internal.WorkbenchWindow$6.close(WorkbenchWindow.java:524)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer$7.shellClosed(WBWRenderer.java:629)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:99)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5219)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1349)
	at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:669)
	at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:1303)
	at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1983)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:5819)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5490)
	at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:9555)
	at org.eclipse.swt.widgets.Display.eventProc(Display.java:1275)
	at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
	at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
!SESSION Mon Apr 01 09:19:05 UTC 2019 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2019-04-01 09:19:05.982
!SESSION 2019-04-01 09:19:05.861 -----------------------------------------------
java.version=10.0.2
!ENTRY org.eclipse.osgi 4 0 2019-04-01 09:19:07.079
!ENTRY org.eclipse.core.resources 2 10035 2019-04-01 09:19:17.263
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 2 0 2019-04-01 09:19:18.523
!SUBENTRY 1 org.eclipse.ui 2 0 2019-04-01 09:19:18.524
!ENTRY org.eclipse.ui 2 0 2019-04-01 09:19:20.130
!SUBENTRY 1 org.eclipse.ui 2 0 2019-04-01 09:19:20.130
!ENTRY com.xilinx.sdk.utils 0 0 2019-04-01 09:19:22.996
!MESSAGE XSCT Command: [::hsi::utils::init_repo], Thread: Worker-2
!ENTRY org.eclipse.core.jobs 4 2 2019-04-01 09:19:23.049
!STACK 0
	... 3 more
!ENTRY org.eclipse.cdt.core 1 0 2019-04-01 09:44:41.781
!MESSAGE Indexed 'helloworld' (0 sources, 0 headers) in 0.01 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!SESSION 2019-10-23 09:38:05.093 -----------------------------------------------
eclipse.buildId=2019.1
java.version=11.0.4
java.vendor=Ubuntu
!ENTRY org.eclipse.core.resources 2 10035 2019-10-23 09:39:18.001
!ENTRY org.eclipse.osgi 4 0 2019-10-23 09:39:18.707
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:626)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
	... 23 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
	... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-10-23 09:39:18.721
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
	at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
	at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
	at org.eclipse.osgi.container.Module.doStop(Module.java:634)
	at org.eclipse.osgi.container.Module.stop(Module.java:498)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
	at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
	... 21 more
My .ini file looks like this:
-startup
plugins/org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.400.v20160518-1444
-showsplash
com.xilinx.sdk.product
--launcher.GTK_version
2
-vmargs
-Xms64m
-Xmx512m
--add-modules=ALL-SYSTEM
I'm running Java 11.0.4:
openjdk version "11.0.4" 2019-07-16
OpenJDK Runtime Environment (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3)
OpenJDK 64-Bit Server VM (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3, mixed mode, sharing)
Is there an explanation/fix for this? I've searched the error messages from the log but haven't found a solution that works.
Thanks for the help
ibaie
Hi @chrisdowney
Does the issue happen regardless the workspace location or having a clean folder? Sometimes a corrupted workspace might generate this kind of issues.
Ibai
