Error build device tree board support package
I've tryied to build a device tree for a zc706 board but I have these errors :
ERROR:EDK:2950 -
Unknown MDT DataBase Function get_property
ERROR:EDK - device-tree () -
ERROR:EDK:3416 - Error(s) while running TCL procedure generate().
make: *** [ps7_cortexa9_0/lib/libxil.a] Error 2
make: Target `all' not remade because of errors.
Does someone have an idea how I could fix that ?
Re: Error build device tree board support package
There have been some issues with device-tree along with Vivado 2014.1
http://forums.xilinx.com/t5/Embedded-Development-Tools/device-tree-generator-and-xsdk-2014-1-issues/td-p/444086
Can you confirm which version of Vivado you are using?
--Hem
Actually I don't use Vivado, what I did here is,  using ISE 14.5,  build a new design on XPS, export it to SDK and then try to build the device tree. Could not use Vivado be a reason of my errors ?
I also have Vivado istalled, I will tell you the version tomorow morning.
Bruno
Hi, I have Vivado 2013.4
i have the same error with ISE 14.7.
This issue is under investigation through a webcase and I would post the solution as soon as it is known.
Debraj
I've just faced same problem. I've got two versions of Device tree generator. The new one (updated 04.07.14) is producing error 2. But the old one (from 29.11.13) works fine on the same project. Maybe there are some errors is new generator?
Thanks for your post, I just tryied an older version and it worked perfectly.
Where can we find this older version ((from 29.11.13) )? Github maybe? Thanks
Old version is in attachment.
Thank you very match !!!
Thanks You for the device-tree-bsp.
Saved a lot of time and effort.
