Error during SDK
Ihave face following error during SDK implemenation.
Description Resource Path Location Type
conflicting types for 'kill' kill.c /standalone_bsp_0/ps7_cortexa9_0/libsrc/standalone_v5_5/src line 46 C/C++ Problem
make: Target 'all' not remade because of errors. standalone_bsp_0 C/C++ Problem
make[1]: Target 'libs' not remade because of errors. standalone_bsp_0 C/C++ Problem
ps7_cortexa9_0/libsrc/standalone_v5_5/src/make.libs] Error 2 standalone_bsp_0 line 28 C/C++ Problem
standalone_libs] Error 1 standalone_bsp_0 line 68 C/C++ Problem
In info :- Description Resource Path Location Type
previous declaration of 'kill' was here standalone_bsp_0 line 176, external location: c:\xilinx\sdk\2019.1\gnu\aarch32\nt\gcc-arm-none-eabi\arm-none-eabi\libc\usr\include\sys\signal.h C/C++ Problem
And System.mss is  Failed to create the part's controls
Hi @nwp-100
Thanks for the additional detail, definitively porting projects between versions is not a supported use case and specially if we talk about porting BSP code. The issue here is that the standalone BSP back in 2016.2 use to have the kill function defined in the code while in 2019.1 it is provided by the toolchain library. I would recommend you to just port/copy the applicatio project while the BSP is generated with 2019.1. Then you just need to tweak/modify the application code in order to make it usable.
Ibai
Hi @nwp-100
The error log is quite meaningfull, I mean, you ahve two definitions of kill, one within the standalone BSP sources and one within the toolchain. Could you provide more details on how to reproduce the issue? I mean, what kind of application did you create (C or C++), libraries selected....
Ibai
I  use 2019.1 verion of Vivado and in that all thing working ok , but the project file is 2016.2 version and when i try to open with SDK it show me above errors.
Hi @nwp-100
Ibai
Can you tell me how to port code into 2019.1
