chrisfisch
Error during building my first library for SDK
I'd like to create my first own library. I found the est_rm.pdf and psf_rm.pdf and nearly understood the design flow.
But when I copy my files into the Path (see below) an error occurs and I cannot open the BSP settings in SDK
"Internal error in the platform settings dialog"
The objective is to implement a basic small library for the sd card and a modified Xilfatfs.
So far my C Project works fine and the next step is to transform it into a library.
I made the following files:
MyLib_v2_1_0.mld
OPTION psf_version = 2.1.0 ;
BEGIN LIBRARY MyLib
 OPTION DESC = "MyLib for a sd card" ;
 OPTION DRC = mylib_drc;
 OPTION copyfiles = all;
 OPTION REQUIRES_OS = (standalone xilkernel);
END LIBRARY
I dont have any .tcl file (" TCL is not necessary for a library", see est_rm.pdf) in my data folder.
I also modified a pre-existing Makefile (xilmfs_v1_00_a Makefile)
to :
# Makefile for MyLib
COMPILER=
ARCHIVER=
CP=cp
COMPILER_FLAGS=-O2 -c -g
EXTRA_COMPILER_FLAGS=
LIB=libxil.a
RELEASEDIR=../../../lib
INCLUDEDIR=../../../include
INCLUDES=-I./. -I${INCLUDEDIR}
LIBSOURCES=xilfatfs_alloc.c xilfatfs_close.c xilfatfs_directory.c	\
	xilfatfs_fat.c xilfatfs_fat16.c xilfatfs_fat32.c xilfatfs_filespec.c	\
	xilfatfs_filestatus.c xilfatfs_open.c xilfatfs_part.c xilfatfs_read.c xilfatfs_wd.c \
	xilfatfs_stats.c xilfatfs_bufcache.c xilfatfs_chdir.c xilfatfs_mkdir.c \
	xilfatfs_write.c xilfatfs_remove.c sd_main.c
LIBOBJS=$(LIBSOURCES:%.c=%.o)
INCLUDEFILES=sd_stdio.h
libs: ${RELEASEDIR}/${LIB}(${LIBOBJS})
(%.o):%.c
	$(COMPILER) $(COMPILER_FLAGS) $(EXTRA_COMPILER_FLAGS) $(INCLUDES) $< -o $*.o
	$(ARCHIVER) -r ${RELEASEDIR}/${LIB} $*.o
	$(RM) $*.o
include:
	${CP} $(INCLUDEFILES) $(INCLUDEDIR)
clean:
	rm -rf *.o
 The path of this Makefile and my .c and .h File is MyLib\src\
The Path of sw_services is :
C:\Xilinx\13.2\ISE_DS\EDK\sw\ThirdParty\sw_services\MyLib
 Should I create a .tcl File ?
Greets
