wisnuk@w
Error generating bsp sources: Failed in generating sources
Hello there!
I have problem while generating bsp sources , i have already commited following solutions : https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK2018-1-error-generating-BSP-for-microblaze-mcs-with-external/td-p/859919#
but it remains the same. an error message is shown in following file. and also I attached some file maybe could give a clue
wisnuk@w
Thankyou for your attention actually i have solved the issue by following this thread : https://forums.xilinx.com/t5/Embedded-Development-Tools/Problem-in-generating-BSP-in-SDK/m-p/651827
stephenm
Can you share the HDF and I'll replicate
wisnuk@w
thanks for response i'm not be able to upload because file extension , may i send to you by other platform?
wisnuk@w
wisnuk@w
