tug05169
Error in SDK with FPGA Board
I'm not sure if this is the right forum but I created a design in Vivado 2018.3 and after, launched to SDK. I wrote code in SDK to run on my Zybo board but whenever I try to run it, I get the following error message:
Error while launching program: Could not find FPGA device on the board for connection 'Local.'
However, the device is read on my computer and the light on the board is on. How can I fix this?
xilinxacct
Instructor
Instructor
@tug05169
See if this helps... https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-Program-FPGA-failed/td-p/465446
If so, please mark as solution accepted. Kudos also welecomed. :-)
stephenm
Is your board connected directly to your board? Or is it remote, or via a virtual machine?
can you open XSCT in SDK, and do the following:
  • connect
  • targets
You should see the arm dap, and the pl. If not, then you should look at your cable drivers
tug05169
My board is connected to my computer through a usb. I am running it on a 2017 Mac but I used boot camp to partition the hard drive so I can run Windows. I will try your suggestions, thanks!
