paulleons
Error in compiling
I am trying to compile a xilkernel code in sdk 14.6. I get the following error when I compile the project. Could anyone tell me   the cause of this error. Is it because Xilkernel libraries are not included? I have attached the MSS file.
'Building target: gbgfcd.elf'
'Invoking: MicroBlaze gcc linker'
mb-gcc -Wl,-T -Wl,../src/lscript.ld -L../../gbgfcd_bsp/microblaze_0/lib -mlittle-endian -mxl-barrel-shift -mxl-pattern-compare -mcpu=v8.50.b -mno-xl-soft-mul -Wl,--no-relax -Wl,--gc-sections -o "gbgfcd.elf" ./src/helloworld.o ./src/platform.o -lxilkernel
c:/xilinx/14.6/ise_ds/edk/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/4.6.4/../../../../microblaze-xilinx-elf/bin/ld.exe: cannot find -lxilkernel
collect2: ld returned 1 exit status
make: *** [gbgfcd.elf] Error 1
Tags (3)
htsvn
Can you please check in the SDK settings to make sure that the Software Platform inferred flags is set to "lxilkernel" as shown here in the snapshot attached?
--HS.
paulleons
Thanks for the reply . This configuration is already set by the tool itself. Could there be any other reason?
htsvn
That is strange to see the error. Can you try to compile the UG758 design to confirm if this is a design specific issue?
http://www.xilinx.com/support/documentation/sw_manuals_j/xilinx14_6/ug758.pdf
--HS
