sin
Error in sleep.h
florentw
HI @sin
The error looks weird. Why this to prototype have an error an not the ones below using the same types...
Could you give more information:
  • What OS are you using?
  • What version are you using?
  • What is the design used?
  • What steps are you doing to produce this errors?
  • What error message in displayed in the error tab?
Florent
florentw
HI @sin
Florent
