Error message when enabling shared memory (config_shm)
In MSS I have the following enabled: systmr_spec, config_pthread_support, config_sched, config_time, config_sema, config_msgq (and use_malloc) and everything works just fine.
But when I enable config_shm I get the following error: "cannot find -lxilkernel"
How can I solve this problem?
Re: Error message when enabling shared memory (config_shm)
The problem was caused because I hadn't set the shared memory table size. Adding this line to the MSS solved the problem: PARAMETER SHM_TABLE = (4). I find the error message was misleading.
OK there's definitely a bug in SDK. I just went cleaned the project via project->clean and now I'm seeing this error: "sys/init.h" no such file or directory. When I remove sys/init.h in my code then it can't find xmd.h.
Here's the MSS of the working version:
BEGIN OS
PARAMETER OS_NAME = xilkernel
PARAMETER OS_VER = 5.01.a
PARAMETER PROC_INSTANCE = microblaze_0
PARAMETER STDIN = rs232_uart_1
PARAMETER STDOUT = rs232_uart_1
PARAMETER SYSTMR_SPEC = true
PARAMETER SYSTMR_DEV = axi_timer_0
PARAMETER SYSINTC_SPEC = microblaze_0_intc
PARAMETER CONFIG_PTHREAD_MUTEX = true
PARAMETER CONFIG_NAMED_SEMA = true
PARAMETER CONFIG_MSGQ = true
PARAMETER CONFIG_TIME = true
PARAMETER CONFIG_SEMA = true
PARAMETER USE_MALLOC = true
PARAMETER MSGQ_CAPACITY = 100
PARAMETER VERBOSE = true
PARAMETER DEBUG_MON = true
PARAMETER CONFIG_KILL = true
PARAMETER CONFIG_YIELD = true
END
And here's the MSS of the not working version:
BEGIN OS
PARAMETER CONFIG_SHM = true
END
