tarzandavid
Error occur when adding custom OPB IP, " must have atleast 1 master assigned!"
Hi everyone,
I am using EDK 10.1.03 and trying to add a custom OPB IP to control an Led. After done the steps of creating the IP and configurating address ,port connection and also MPD editing, Hdl editing, I  generated the bitstream but failed, with the following error shown:
Can someone give me any suggestions? Thanks in advance!
Check platform configuration ...
IPNAME:plb_v46 INSTANCE:mb_plb -
D:\Projects\Spartan3A_projects_Myip\OPB_IP_LED_Spartan3A\system.mhs
line 38 - 2 master(s) : 2 slave(s)
IPNAME:lmb_v10 INSTANCE:ilmb -
line 45 - 1 master(s) : 1 slave(s)
IPNAME:lmb_v10 INSTANCE:dlmb -
line 52 - 1 master(s) : 1 slave(s)
IPNAME:opb_v20 INSTANCE:opb_v20_0 -
line 149 - 0 master(s) : 1 slave(s)
ERROR:MDT - IPNAME:opb_v20 INSTANCE:opb_v20_0 -
   D:\Projects\Spartan3A_projects_Myip\OPB_IP_LED_Spartan3A\system.mhs line 149 - must have atleast 1 master assigned!
ERROR:MDT - platgen failed with errors!
make: *** [implementation/system.bmm] Error 2
Done!
tarzan
xiaofeip
Hi Tarzan,
The error message says that there's no master on the OPB bus. OPB needs at least a master on the bus.
Where is the OPB bus connected to? Is there a plb2opb bridge? Is your peripheral an OPB master?
-XF
