04-23-2013 06:02 AM
Dear all,
Im traing to run the rgb2gay example:
1) I have create the edk proces with Simulink
2) I add the pcode created with Simulink and Sysgem to my EDK project.
3) Affter generatting the Netlist, the Bitstream and export de Desing I have created the Sofrware using SDK
4) I have used the code that is shown in the example (System Generator for DSP User Guide" document, page 155 ):
5) I have programed the FPGA OK and run the code.
6) In the serial port I get:
Hello World
-- Entering main() --
Hello World
Hello World
Hello World
Hello World
The same 2 lines are repeated indefinitely
what is happening?? why the program does no pass the xc_create line??
If I add a prinf affter this line... nothing happens... the two lines remains (Hello World -- Entering main() --)
The other point is that I can not find the lines
/* Definitions for peripheral SG_PLBIFACE_0 */
#define XPAR_SG_PLBIFACE_0_DEVICE_ID 0
in to the xparameters.h in order to fix the index of RGB2GRAY_PLBW_ConfigTable .... I have assumed that it is 0...
Many thanks in advance for your help.
BR
The code that I have used:
#include "xparameters.h"
#include "stdio.h"
#include "xutil.h"
// header file of System Generator Pcore
#include "rgb2gray_plbw.h"
RGB2GRAY_PLBW_Config RGB2GRAY_PLBW_ConfigTable[0];
int main (void) {
int i;
uint32_t gray, red, green, blue;
print("-- Entering main() --\n\r");
xc_iface_t *iface;
xc_from_reg_t *fromreg_gray;
xc_to_reg_t *toreg_red, *toreg_green, *toreg_blue;
// initialize the software driver
xc_create(&iface, &RGB2GRAY_PLBW_ConfigTable[0]);
// obtain the memory locations
xc_get_shmem(iface, "result", (void **) &fromreg_gray);
xc_get_shmem(iface, "red", (void **) &toreg_red);
xc_get_shmem(iface, "green", (void **) &toreg_green);
xc_get_shmem(iface, "blue", (void **) &toreg_blue);
for (i=15; i<30; i++){
red = i;
green = i + 10;
blue = i + 20;
// Write RGB value to peripheral
xc_write(iface, toreg_red->din, red);
xc_write(iface, toreg_green->din, green);
xc_write(iface, toreg_blue->din, blue);
xil_printf("R = 0x%x, G = 0x%x, B = 0x%x -- ",
red, green, blue);
xc_read(iface, fromreg_gray->dout, &gray);
xil_printf("Gray = %x \n\r", gray);
print("-- Exiting main() --\n\r");
return 0;
04-23-2013 06:07 AM
Since there is no "Hello World" in the C program you posted, I think the problem is
that you are not picking up the correct .elf file when you build the project. If you created
your code starting from the Hello World example, it is possible that the project settings
are still pointing to the Hello World code and not the code you have changed. Another
possibility is that your software was never actually built, for example there was a
linker error, etc. and the .elf file is stale.
04-23-2013 06:37 AM
Thanks for you quickly reply...
You are rigth about the Hello word...
When I have copy the code i just removed...
I am really sure that I am running the right code ...
If I change the print string I see it in the serial port...
The problem is nothing after the xc_create is executed....
I mean, if I add print(" This line is after xc_create" )... I never see this in the serial port.
There the code:
#include "stdio.h"
#include "xutil.h"
//void print(char *str);
int main (void)
//init_platform();
int i;
print("Hello World\n\r");
xc_iface_t *iface;
red = i;
green = i + 10;
blue = i + 20;
red, green, blue);
return 0;
cleanup_platform();
return 0;
04-23-2013 06:58 AM - edited 04-23-2013 06:58 AM
This line looks suspicious:
It seems to be defining a zero-element array of type RGB2GRAY_PLBW_Config. Later
you are using the address of its first element:
So perhaps this is causing other things to get inadvertently overwritten?
04-23-2013 07:48 AM
RGB2GRAY_PLBW_Config is a structure, created directy by the EDK.
The 0 is due to the ID devide... (as far as I understood in the System Generator for DSP document):
There can be multiple instances of a System Generator pcore in an XPS project. Each of the
instances is associated with a device ID, which can be found in “xparameter.h”. Assume
that the instance of interest has a device ID of 0 based on the following information in
“xparameter.h”.
/* Definitions for driver SG_PLBIFACE */
#define XPAR_SG_PLBIFACE_NUM_INSTANCES 1
I just copy the line xc_create(&iface, &RGB2GRAY_PLBW_ConfigTable[0]);
from the tutorial....
typedef struct {
uint32_t version;
// Pointers to low-level functions
xc_status_t (*xc_create)(xc_iface_t **, void *);
xc_status_t (*xc_release)(xc_iface_t **);
xc_status_t (*xc_open)(xc_iface_t *);
xc_status_t (*xc_close)(xc_iface_t *);
xc_status_t (*xc_read)(xc_iface_t *, xc_r_addr_t, uint32_t *);
xc_status_t (*xc_write)(xc_iface_t *, xc_w_addr_t, const uint32_t);
xc_status_t (*xc_get_shmem)(xc_iface_t *, const char *, void **shmem);
// Optional parameters
// (empty)
// Memory map information
uint32_t result;
uint32_t result_n_bits;
uint32_t result_bin_pt;
// uint32_t result_attr;
uint32_t blue;
uint32_t blue_n_bits;
uint32_t blue_bin_pt;
// uint32_t blue_attr;
uint32_t green;
uint32_t green_n_bits;
uint32_t green_bin_pt;
// uint32_t green_attr;
uint32_t red;
uint32_t red_n_bits;
uint32_t red_bin_pt;
// uint32_t red_attr;
// XPS parameters
Xuint16 DeviceId;
uint32_t BaseAddr;
} RGB2GRAY_PLBW_Config;
04-23-2013 11:49 AM
The problem I see is that when you allocate memory for an array of structures, the number in
the square brackets is not an index into the array, but the size of the array. A size of zero would
say you don't have any instances, and it's not clear what the pointer to the first element would
give you. That's why it seems that the [0] in the first line I mentioned should be [1] if you have
one instance, or if you have a definition of the number of instances then you could use
that like [XPAR_SG_PLBIFACE_NUM_INSTANCES]. Then if you happened to add more
instances you'd allocate the memory for the appropriate number of structures.
04-24-2013 01:41 AM
Many thanks for you help.
At the end, the problem was that I had to add the IP driver to the SDK environment
Problem solved!
