Scholar milosoftware
Error while launching program: AP transaction error, DAP status 30000021
I'm bringing up a new ZynqMP board, with a xczu9eg chip on it.
I configured the PS in vivado, built an FSBL, and launch it over JTAG with the XSDK. I then get this mysterious eror message:
What does it mean or where can I find more information?
Re: Error while launching program: AP transaction error, DAP status 30000021
check these posts
https://forums.xilinx.com/t5/Embedded-Development-Tools/AP-transaction-Error/td-p/369465
http://www.xilinx.com/support/answers/64715.html
Thanks and Regards
Balkrishan
This issue is setting, You are trying to use feature which is not supported by end device . I saw similar error with DDR. In DDR PCW GUI, Burst length is set to 16, however device only supports burst length of BL8 and BC4.
After changed burst length to 8, DDR works.
Thanks and Regards
Balkrishan
I get this message regardless of what I try, way before I get to the DDR part. For example, if I only run the MIO configuration part of the PS initialization, so no DDR involved in any way, I already get that failure:
xsdb% source /opt/Xilinx/SDK/2016.2/scripts/sdk/util/zynqmp_utils.tcl
xsdb% targets -set -filter {name =~"*APU*"}
xsdb% loadhw design_1_wrapper_hw_platform_0/system.hdf design_1_wrapper_0
xsdb% source design_1_wrapper_hw_platform_0/psu_init.tcl
xsdb% init_ps [subst {$psu_mio_init_data }]
xsdb% AP transaction error, DAP status 30000021
Using XMD, I get the following:
XMD% connect arm  hw
JTAG chain configuration
Device   ID Code        IR Length    Part Name
 1       04738093          12        xczu9eg
 2       5ba00477           4        arm_dap
ERROR:
    Unsupported CoreSight ROM: JEP-106 ID 0x93
Visitor phani.kara
In our case, enabling DRAM training has done the trick if this helps anyone.
The AP transaction error means that DAP has seen an error response while accessing a memory address. It's possible that the ps init is corrupting the system. When you see this error, can you run "set errorInfo" in xsdb, to get the stack trace of the error, which should tell you which memory access has caused the failure.
XMD is deprecated and doesn't support new devices, including 9eg
