djc
Error while lunching program : Memory read error at 0xFD0C00AC. AXI AP transaction error , DAP status 30000021
Hello guys,
im running the most basic manual from xilinx The "hello world"
followed every single step for sevral times and its not working.
i have tried the other posts answers , and it did me no good .
how do i solve this error ?
and is it related to this log warnings ?
Be glad for a quick assistance ,
Daniel,
arpansur
Hi @djc,
What is present at the address 0xFD0C00AC?
Which device are you targeting? Is it custom board or Xilinx Evaluation board?
Try changing linker script to run code from a different location. Please make sure you restart the board to try the code on hardware.
Arpan
arpansur
Hi @djc,
Arpan
djc
Hi arpan,
I am working with the zynq ultrascale+ zcu 102 .
the address is the one written in the tutorial .
what code do you refer to when saying linker ?
tnx,
Daniel
arpansur
Hi @djc,
As you are using zcu102, please use the pre-defined platform to check if you are able to program the same.
Regarding the linker script, right click on application and click on the generate linker script and verify the memory you are using. Try with a different memory to see if it works.
If there is a DAP error already, please restart the board.
Arpan
Hi @djc,
What worked for you? I changed the 'Hardware Platform' as suggested here and restarted the board for any existing DAP errors but I still end up with the Memory read error. Did you take any other steps other than what was suggested here?
Nikhil
