Errors in creating application project in XSDK
According to UG1186,"Building Remote Applications in Xilinx SDK"
Create new application project in XSDK2018.1, select
freertos10, zcu102,psu_cortexr5_0,OpenAMP echo-test,
after building workspace,
Re: Errors in creating application project in XSDK
You can append to the default flags, but do not remove any existing flags, unless you're sure
Hi @altair5683,
These instructions are supported by FPU. Did you change the extra_compiler_flags in the BSP settings? You should have -mfloat-abi=hard -mfpu=vfpv3-d16. These are part of the default flags
Do i need to change the value of "extra compiler flags" to the default?
