Excluding non-used code by the linker
Hi All,
I am using MB with ISE12.4 and I have designed a custom IP and its driver. I noticed that the linker produces ELF file containing all functions in a file if I called any function in that file even if I am only using that function. I changed build settings to release but still all functions included in the output. Are there any option to instruct the compiler and linker to link ony used code and remove unused code? I need help ASAP please.
M. Abdulghany
Re: Excluding non-used code by the linker
