Export data from DDR3 to any file for Matlab
Hi all,
I am saving my data from ADC in to DDR3 through DMA transfer and i want to print/export all data from DDR3 for the further analysis on Matlab. Yes i can print all samples on SDK console but there are some limitations, i cant print more than around 15000 sample on SDK console.
If anybody know the solution then i will be very thankful to you.
Umair
Re: Export data from DDR3 to any file for Matlab
There is a memory dump feature in SDK, but I think it is from 14.6 and higher versions. Try that
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/SDK_Doc/tasks/sdk_t_memory_dump_restore.htm
Thanks for your reply, I am using ISE 14.4 so is it possible to use SDK 14.6 with XPS 14.4??
