Visitor etx01cl
External Interrupt problem if using a differential input buffer
Hi all,
I am experiencing a problem when trying to generate an interrupt from an external signal if I am using a differential input buffer.
For the purpose, I am receiving an interrupt from an external chip on a LVDS input. To interface the input, I am inserting a differential input buffer:
BEGIN util_ds_buf
 PARAMETER INSTANCE = ibuff_CMX_IRQ
 PARAMETER HW_VER = 1.00.a
 PARAMETER C_BUF_TYPE = IBUFDS
 PORT IBUF_OUT = xps_CMX_INT
 PORT IBUF_DS_N = fpga_0_CMX_INT_N
 PORT IBUF_DS_P = fpga_0_CMX_INT_P
END
 In the interrupt controller, I have added the "xps_CMX_INT".
BEGIN xps_intc
 PARAMETER INSTANCE = xps_intc_0
 PARAMETER C_BASEADDR = 0x81800000
 PARAMETER C_HIGHADDR = 0x8180ffff
 BUS_INTERFACE SPLB = mb_plb
 PORT Irq = Interrupt
 PORT Intr = xps_spi_DRX_L9826_IP2INTC_Irpt & xps_CMX_INT & xps_timer_1_Interrupt & RS232_DCE_Interrupt
END
The problem is when synthetizing, I get errors:
ERROR:MDT - C_NUM_INTR_INPUTS (xps_intc) - can't use non-numeric string as
   operand of "-"
       while executing
   "expr {abs($svec - $fvec) + 1}"
       (procedure "hw_intc_core_v1_00_c::update_num_intr_inputs" line 21)
       invoked from within
   "hw_intc_core_v1_00_c::update_num_intr_inputs "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_num_intr_inputs" line
   8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_num_intr_inputs 87183544"
ERROR:MDT - IPNAME:xps_intc INSTANCE:xps_intc_0 -
   c:\Local\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_intc_v1_00_a\data
   \xps_intc_v2_1_0.mpd line 48 - error computing override value for
   C_NUM_INTR_INPUTS using tcl
ERROR:MDT - C_KIND_OF_INTR (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_intr" line 32)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_intr "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_intr" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_intr 87185196"
   \xps_intc_v2_1_0.mpd line 49 - error computing override value for
   C_KIND_OF_INTR using tcl
ERROR:MDT - C_KIND_OF_EDGE (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_edge" line 55)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_edge "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_edge" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_edge 87185420"
   \xps_intc_v2_1_0.mpd line 50 - error computing override value for
   C_KIND_OF_EDGE using tcl
ERROR:MDT - C_KIND_OF_LVL (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_lvl" line 55)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_lvl "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_lvl" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_lvl 87187016"
   \xps_intc_v2_1_0.mpd line 51 - error computing override value for
   C_KIND_OF_LVL using tcl
If not using a differential input buffer, it does not complain...
Thanks in advance,
Best Regards,
Cédric.
