FSBL File not found
please help me. when i run hello world this error is coming.
iam using vivado 2020.1 and zynq ultrascale+mpsoc
Did you build the system? You have enabled the build boot components in the platform. So, you need to build the system to compile the fsbl. Can you highlight the system_wrapper under Explorer and hit that hammer icon?
Hi balu.bhanoth@gmail.com
Did you enable the Generate Boot Components box while creating a platform?
Best Regards,
Nutan
How to enable the Generate Boot Components
i am unable see
when i run hello world this warning is coming. if i am proceed fsbl error is coming
i am  enable the Generate Boot Components box while creating a platform sir
in middle this warning is coming
Thats fine. You dont want to debug the fsbl. You want it to config the ps
In My design i am using DDR4 3200 is it suitable for XQZU3EGSFRC784-1M device
When i run Hello World it hangs at psu_init.tcl
hanging at psu_init
please help
