wmaguire
FSBL SD Boot problems with Vivado 2015.2
Hi all,
We recently upgraded from Vivado 2014.2 to Vivado 2015.2 and see issues with the SD card booting, in particular the FSBL code.  We have had no issues with the 2014.2 suite in this area.  There appears to be 2 problems.  We use 32GByte SanDisk Ultra SD Cards.  Single stepping the fsblcode
we note that we are unable to set it to 400kHz.  We can pass this point if we set it to 50 MHz ie use XSDPS_CLK_50_MHZ.
* Change the clock frequency to 400 KHz
Status = XSdPs_Change_ClkFreq(InstancePtr, XSDPS_CLK_400_KHZ);
if (Status != XST_SUCCESS) {
Status = XST_FAILURE;
goto RETURN_PATH ;
The second issue is in the file ff.c  with the check
if ((stat & STA_NOINIT) != (BYTE)0U) { /* Check if the initialization succeeded, used to be (BYTE)0U) */
return FR_NOT_READY; /* Failed to initialize due to no medium or hard error */
As can be seen from the debug window the stat = 0, the expression (BYTE) 0U = 0 but the test
Fails.
The device we are using is the xc7z045ffg676-1.
Looks like there maybe a compiler bug.
Walter
wmaguire
Hi All,
Last bit of the previous post covering the stat test is incorrect.  The debugger does indicate that it enters this line of code by highlighting it but it actually doesn't enter it.
It now boots the SD Ultra card if I make sure to change the 400kHz to 50MHz.
The problem is, why did it work for 2014.2 without this change.  Was the speed reduced for the initial SD card transactions?
Walter
