kalle1
Feature request: Static allocation for FreeRTOS
Would it be possible to add built-in support for static allocation to the FreeRTOS that ships with the Xilinx SDK? I am able to add this myself by including
set val [common::get_property CONFIG.support_static_allocation $os_handle]
if {$val == "false"} {
    xput_define $config_file "configSUPPORT_STATIC_ALLOCATION" "0"
} else {
    xput_define $config_file "configSUPPORT_STATIC_ALLOCATION" "1"
in freertosXX_xilinx.tcl, and
PARAM name = support_static_allocation, type = bool, default = true, desc = "Set to 1 to enable static allocation of FreeRTOS objects such as tasks and queues.";
in freertosXX_xilinx.mld, but each time there is an update (or I have to move between PCs) I again have to go through this process. It would be nice if this was included by default.
ibaie
Hi @kalle1,
I just reported your request to the development team, but it might take some time until you can see this feature available.
Meantime the best way is to have your customized FreeRTOS in a shared folder and use the custom repositories to share the driver within different PCs (This way you don't need to modify the files more than once).
Ibai
Ibai
ibaie
Hi @kalle1,
Ibai
Ibai
