3008202060
File directory when using linux application debug
Hi all,
Where should I put the file when I try to read the file as a argv? For example, if I want to read file XXX.cfg, where should I put the file? The same directory as the elf file?
Thanks a lot.
sadanan
You can either specify the full paths, or in the application tab, change the working directory to any path, and put the files in that directory
stephenm
In the debug configuration, there is an arguments tab. You can use that
3008202060
Suppose the screenshot is my arguments, I want to read the cifar.data file. Where should I put that file on the sd card(since I tried to run liunx application that boot from sd card)?
sadanan
