coldwell
Fixed interval timer is not a valid timer for FreeRTOS?
Using Vivado 2017.4 I have a block design that uses a fixed interval timer (FIT) to generate a timer interrupt on a Microblaze
https://www.xilinx.com/support/documentation/ip_documentation/fit_timer/v2_0/pg110-fit-timer.pdf
this works fine with a standalone BSP. Now I want to try it with FreeRTOS, but when I try to generate the BSP in SDK, I get the error below, which indicates that it doesn't consider the FIT a valid timer for FreeRTOS purposes. Is this an oversight, or an actual limitation of the FIT?
11:03:13 ERROR : (XSDB Server)ERROR: [Hsi 55-1545] Problem running tcl command ::sw_freertos901_xilinx_v1_1::FreeRTOS_drc : FreeRTOS for Microblaze requires an axi_timer or xps_timer. The HW platform doesn't have a valid timer.
while executing
"error "FreeRTOS for Microblaze requires an axi_timer or xps_timer. The HW platform doesn't have a valid timer." "" "mdt_error""
(procedure "mb_drc_checks" line 69)
invoked from within
"mb_drc_checks $sw_proc_handle $hw_proc_handle $os_handle"
(procedure "::sw_freertos901_xilinx_v1_1::FreeRTOS_drc" line 10)
invoked from within
"::sw_freertos901_xilinx_v1_1::FreeRTOS_drc freertos901_xilinx"
ERROR: [Hsi 55-1440] Error(s) while running DRCs.
11:03:13 ERROR : (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.
11:03:13 ERROR : Error generating bsp sources: Failed in generating sources
11:03:13 ERROR : Failed to generate sources for BSP project freertos901_xilinx_bsp_0
org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details.
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2240)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2267)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
coldwell
Actually, looking through the FreeRTOS source code it looks like it really is a requirement. Unfortunately, there is no support for the FIT.
coldwell
