Observer linuxbios
Flash Programming
Please give me the solution.
I am using VIVADO 2014.4 and SDK 2014.4.
I tried to program the flash on KC705 ev kit.
But the following message on SDK tool is printed.
" ERROR: Unable to create temporary cmd file: cmd.bat"
* Performing CFI Query on the flash part(s)...done.
* Flash part information:
* Device Algorithm       : Intel/Sharp Extended
* Number of flash parts  : 1
* Mode of each flash part : 16 bits wide
* Size of each flash part : 128 MB
* Flash sector config     : DEFAULT
* Compiling flashwriter (Block Erase Mode)...* Compiling flashwriter sources
* ERROR: Unable to create temporary cmd file: cmd.bat
* Sending CMD_EXIT to writer...
* Flashwriter terminating !
Re: Flash Programming
Which Flash are you targetting to program?
Praveen
Observer linuxbios
I am using KC705 ev kit.
The Parallel Flash (28F00AP30)
hi,
would that be possible to check if the flash on board is functional?
http://www.xilinx.com/support/documentation/boards_and_kits/kc705/2013_4/xtp195-kc705-bist-c-2013-4.pdf
run the example 4.
--hem
