static0192
FreeRTOS Version in Xilinx SDK 2019.1
What version of FreeRTOS is bundled with Xilinx SDK 2019.1?
ibaie
Hi @static0192 ,
You are right, the latest release is 10.1.1 of FreeRTOS kernel. You can take a look to the repository history of the ThirdParty BSP providers used within the SDK to get some insight .
https://github.com/Xilinx/embeddedsw/commits/master/ThirdParty/bsp
Ibai
static0192
Looking through some source code, I identified in `FreeRTOS.h` that the kernel used is version 10.1.1. Could someone confirm this?
ibaie
Hi @static0192 ,
Ibai
