Participant sythez
FreeRTOS floating data corruption
Hello, I am using vivado 2017.3 and freertos v9.0.1.
I had floating data corruption.
In my task, arithmetic result using double variables  has fault randomly such as nan.
I declare portTASK_USES_FLOATING_POINT(); before the loop of my task but data corruption is not solved.
and I do not use memcpy / memset .
I looked this document but I can not change the configUSE_TASK_FPU_SUPPORT to 2.
https://www.freertos.org/Using-FreeRTOS-on-Cortex-A-Embedded-Processors.html#floating-point
anyone got solution ?
Re: FreeRTOS floating data corruption
Hi @sythez
Could you provide more details about the target? Are you building for Microblaze or ARM processors?
Ibai
Participant sythez
Hi @ibaie  thanks for your reply
I am using ZC706 and freertos v901.
The issue is the double type data from task stack (at ddr3) is corrupted. some time is right value, other time is not valid (such as nan, inf or odd value)
I have 3 tasks(100ms) and 1 interrupt(~1ms)
I have some development using below link :
https://forums.xilinx.com/t5/Embedded-Development-Tools/Feature-request-Static-allocation-for-FreeRTOS/td-p/847801
so I change the define :
#define configUSE_TASK_FPU_SUPPORT 2
#define configSUPPORT_STATIC_ALLOCATION 1
but, still, have floating data corruption.
