barrygmoss
Fsbl won't compile -- seems to be missing files from hw_platform
I'm using SDK 2016.4 and trying to make some minor modifications to an old design. However, I keep getting a fatal error thatduring the fsbl compilation that SDK can't find the ps7_init.h file, despite it being visible in the project explorer. Any suggestions how to fix this up? I've tried going back to earlier archived versions of the design, re-exporting the hw definition from Vivado, and nothing I do seems to help.
barrygmoss
I finally went on a hunt through the sdk directory of the project. In the fsbl folder, I found that the .project and .cproject files were referencing an obsolete hw_platform that no longer existed. I manually edited the files to the new hw_platform--now the design will compile and everything seems to be working.
sadanan
ps7_init* files are in hw project, and fsbl will have soft links to those files. In your case, it looks like these files have not been linked properly. You can manually create soft links in the fsbl project like this.
Right-click on fsbl/src and select Import
Select General => File system
Browse to the HW project directory where you have ps7_init files and select them
Expand Advanced, and enable the option 'create links in the workspace', and Finish
stephenm
Can you right click on the BSP in Project explorer view in SDK, and select properties. Then under Project References, make sure that the hw_platform is selected
barrygmoss
Thanks for the suggestions, but sadly this didn't work. I followed your instructions. The fsbl src directory now lists all the files from the hw_platform, including the ps7_init.h file (see below), but the design will still not compile even after cleaning the design and performing build all. The error messages are identical to what I showed earlier.
I should note that when I went back to a much earlier version of this project that would compile, the hw_platform files were not all listed until the fsbl. I'm also concerned that with this approach, if I need to update the hw definitions at some point, it may not correctly reference the new definitions because of the local links/copies.
barrygmoss
snehachand007
snehachand007
now it asks for ff.h file missing in fsbl src
