GLIBCXX_3.4.20' not found
When lauching the SDK running on ubuntu 15.10 I get the following error...  Any suggestions?
****** Xilinx Software Development Kit
****** SDK v2015.4 (64-bit)
**** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
Launching SDK with command /opt/Xilinx/SDK/2015.4/eclipse/lnx64.o/eclipse -vmargs -Xms64m -Xmx512m
/opt/Xilinx/SDK/2015.4/lib/lnx64.o/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/x86_64-linux-gnu/libproxy.so.1)
Failed to load module: /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
hi,
it looks that the supported ubuntu versions is Ubuntu Linux 14.04.2 LTS (64-bit)
can you please test this issue on a supported OS as given in page 14 of this document?
--hs
hi,
can you also refer to this link? http://askubuntu.com/questions/575505/glibcxx-3-4-20-not-found-how-to-fix-this-error
--hs
I have the same problem with SDK 16.2 on Ubuntu 16.04LTS, this solution solved my problem
cd SDK/2016.2/lib/lnx64.o/
sudo mv libstdc++.so.6 libstdc++.so.6.orig
sudo ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6  libstdc++.so.6
The original link is here:
http://askubuntu.com/questions/699440/version-glibcxx-3-4-20-not-found
PS: please try to avoid to answer people's question by asking them to try on a supported OS version. XILINX Tools are big and sometimes changing the OS in your working laptop is a bit hard
The error is primarily due to missing libraries.
You can go over the following answer record to check the missing libraries:
https://www.xilinx.com/support/answers/66184.html
cd  Xilinx/Vivado/2017.4/ids_lite/ISE/lib/lin64
mv libstdc++.so.6 libstdc++.so.6.0.8
sudo ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.21 libstdc++.so.6
Can this be marked as solved? Seeing a thread marked as solved will highlight this to other users seeing this issue
Dear All,
I have a problem related to this topic
This is my error
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/p4/SDNet/2017.4/lib/lnx64.o/librdi_ppp.so: /home/p4/Vivado/2016.4/lib/lnx64.o/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /home/p4/SDNet/2017.4/lib/lnx64.o/librdi_ppp.so)
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854)
    at java.lang.Runtime.loadLibrary0(Runtime.java:870)
    at java.lang.System.loadLibrary(System.java:1122)
    at com.xilinx.ppp.Main.main(Unknown Source)
Makefile:64: recipe for target 'compile_no_cpp_test' failed
make: *** [compile_no_cpp_test] Error 1
I did what was recommended here, but now I get this:
sdnet forward.sdnet -busType axi -workDir Test
Xilinx SDNet Compiler version 2017.4, build 2093981
/home/p4/Xilinx/Vivado/2016.4/tps/lnx64/jre/bin/java: symbol lookup error: /home/p4/Xilinx/SDNet/2017.4/lib/lnx64.o/librdi_ppp.so: undefined symbol: _ZN6XilReg5Utils9GetRegKeyERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
Any ideas
Best Regards
Jorge Gomez
