Visitor fft442
Generate SystemACE File error
All is fine in ISE 14.7, but find error in ISE 14.7 now.
My genace.opt is as following:
-jprog
-hw ../Project/Top_CoinTOF.bit
-elf Cruiser/Cruiser_v71.elf
-ace TOF_A.ace
-board user
-configdevice devicenr 1 idcode 0x232d8093 irlength 14 partname xc5vfx100t
-target ppc_hw
When I run command "xmd -tcl genace.tcl -opt genace.opt" in xmd, error as following:
Xilinx Microprocessor Debugger (XMD) Engine
Xilinx EDK 14.7 Build EDK_P.20131013
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Executing xmd script : D:/Xilinx/14.7/ISE_DS/EDK/data/xmd/genace.tcl
XMD GenACE utility. Generate SystemACE File from bit/elf/data Files
Parsing genace option: -opt genace.opt
Parsing genace option file ...
Using GenACE option file : genace.opt
GenACE Options:
    Board      : user
    Jtag Devs  : xc5vfx100t
    FPGA pos   : 1
    JPROG      : true
    HW File    : ../Project/Top_CoinTOF.bit
    ACE File   : TOF_A.ace
    nCPUs      : 1
    Processor ppc_hw_1 Information
        Debug opt : -debugdevice devicenr 1 cpunr 1
        ELF files : Cruiser/Cruiser_v71.elf
        Start PC Address : 0xfffffffc
Open SVF file
Converting Bitstream '../Project/Top_CoinTOF.bit' to SVF file '../Project/Top_CoinTOF.svf'
Executing 'impact -batch bit2svf.scr'
Copying ../Project/Top_CoinTOF.svf File to  TOF_A.svf File
ERROR: Unable to STOP PowerPC Processor
    Check: (1) If the FPGA is Configured Correctly (or)
     (2) If Processor Reset and Clock Ports are Connected Correctly
Error: ERROR: Failed to Write SW Prefix for SVF generation
Can anybody give me some advice?
Visitor fft442
Re: Generate SystemACE File error
correct: All is fine in ISE 14.5, but find error in ISE 14.7 now.
Note that XMD is able to detect the instruction registers of the XC2VP30 (6 bits) along with its two processors in the chain (4 bits each). This indicates that the basic JTAG chain and cable connections are likely correct. However, the processors are not responding to the other JTAG requests.
Check Processor Clocks
Ensure that CPMC405CLOCK has a valid clock, and that the CPMC405CPUCLKEN and CPMC405JTAGCLKEN ports are High. While the PowerPC JTAG controller is clocked by the JTAG clock, the requests from the JTAG unit are serviced by the core clock. If you are using a DCM, check the LOCKED and STATUS ports. Consider connecting the DCM LOCKED signal to the PROC_SYS_RESET EDK IP core.
When probing nets, note that the PPC405 block might have local inversion on some input ports. Check the polarity of individual nets by double-clicking into the PPC405 block in FPGA Editor.
Check Processor Resets
Ensure that the RSTC405RESETCORE, RSTC405RESETCHIP, and RSTC405RESETSYS signals are Low. Make sure the active-low port JTGC405TRSTNEG is High.
Check JTAG Connections
Verify the JTAG chain and cable connections. The JTAG chain connections are especially suspect if XMD cannot detect the IDCODE and IR lengths. A correctly connected JTAG chain should report the correct Device, ID Code, and IR Length for a particular hardware chain, similar to the above error message.
Check iMPACT Options
Use the "Pulse Prog" option in iMPACT. For Virtex-II Pro or Virtex-4 devices, check the Virtex-II "Pulse Prog" check box in iMPACT. Download the bitstream again and connect via XMD.
To enable the option in EDK, the download.cmd file in the "etc" directory has to be modified:
Before:
setMode -bscan
setCable -p auto
identify
assignfile -p 2 -file implementation/download.bit
program -p 2
quit
After:
setMode -bscan
setCable -p auto
identify
program -p 2 -prog
quit
Check UCF constraints
If the design was brought into the ISE tools from EDK, ensure that the UCF has been included in the ISE project.
Check the cable type
Determine whether the download cable you have connected to your computer matches the cable type designated in your EDK XMD project options file or "XMD.ini" file.
1. The xmd options file can be found in the directory "<project_dir>/etc/xmd_ppc*.opt".
- If the cable type does not match, delete the file and launch XMD again from the EDK GUI button.
- Then, select the proper cable type from the dialog pop-up.
2. The "xmd.ini" file can be found in the directory "<project_dir>/xmd.ini".
- Edit the file with the correct cable type, port, and frequency as shown below:
- [-cable type <Xilinx_parallel | Xilinx_parallel3 | Xilinx_platform | usb >
- port <lpt1 | lpt2 | USB2>
- frequency <Cable Frequency>
For Virtex-4 devices, refer to (Xilinx Answer 21820) and (Xilinx Answer 21296).
Additionally, for PPC405, see (Xilinx Answer 22179) and (Xilinx Answer 21820).
For more information on PowerPC 405 functionality, consult the PowerPC 405 Processor Block Reference Guide.
Thanks and Regards
Balkrishan
Visitor fft442
I've tried those advice from you, still not working.
hi,
does the ace file generated in 14.5 work if you program it using 14.7?
--hem
Visitor fft442
yes, the .bit and .elf files are generated in ISE14.7, pack them into .ace in ISE14.5 and it worked.
hi,
glad to know that it worked. can you continue to use this as a work-around?
--hem
