vatsal.naik
Generate Time Delay in SDK
We want to generate time delay between controlling GPIO pins. The easier approach would be to create a loop, but it is not a way to generate a Time delay.
Here is what we are doing,
XGpio_DiscreteWrite(&output, TRIG, 0x1); // Start trigger
for( i = 0; i < Delay; i++){
XGpio_DiscreteWrite(&output, TRIG, 0x0); // Stop trigger
Can someone guide us, what would be the best way to use delay? Appreciate your help!
Best Regards
johnmcd
Depending on optimization, that loop may get removed and therefore, no time delay.
So it will depend on how small a delay you are looking for. There are delays available. Take a look at the baremetal bsp sleep.h file.
johnmcd
ericv
@vatsal.naik
If you declare the variable i as volatile, the compiler will not remove the loop.
You should also disable the interrupts before entering the loop and re-enable them at the end.
A S/W loop will likely have a latency hit before the code lands in the cache, but after that you'll get a precise delay.
vatsal.naik
@johnmcd
Yes, usleep() function from sleep.h seems to work just fine.
Thank you!
Best regards!
vatsal.naik
@ericv I haven't disabled the interrupts, The problem depended on the compile, Every time we got the different delay! Looks like usleep() function is the better way to do it. Thanks for the reply! Best Regards
