Git repository not working for android
I have zynq 702 board , I am try to download git repositry from from xilinx web site :
" http://www.wiki.xilinx.com/Building+Android+BSP+on+ZC702#x-Building%20Linux-Getting%20the%20Linux%20Source "
Cloning linux kernal code command : git clone git://git.iveia.com/scm/xilinx/android/kernel/zynq.git
But I am getting issue " fatal: read error: Connection reset by peer "
Please suggest me how I can download android code.
Piyush Mehta
austin
p,
To create operating systems, one often needs root privileges.  So, since that is often a problem for most companies, one installs a virtual machine, and you give yourself all access to everything (toot, superuser, etc.).
Is this your problem (you don't have root access?).
Austin Lesea
Principal Engineer
Xilinx San Jose
bent93
I ran into the same problem.
Did you ever resolve this?
Thank  you!
