HDL for top level module.
Hi there,
I am a verilog designer with almost negligeble knowledge in VHDL.
However, when I use the 'Create and import Peripheral' wizard in XPS and I attach my peripheral to PLB, the top level module
always seems to be in VHDL.
Therefore the flexibility is reduced as far as I am concerned.
Could you kindly let me know if there s a way out?
Thank you
bassman59
Historian
Historian
Ask in the EDK forum.
golson
 You have an option to use a Verilog "Stub" file.  That is the User Logic file will be in verilog.  You can place your verilog
code within this file.
The Higher Level file IPIF_YourPeripheralName will be in VHDL.  The Higher Level IPIF VHDL file will
use the lower level verilog files.
Gary
There is not much about verilog useage in the XAPP967 App Note.  But it might be of some help.
shoaib.223
Hi All,
I want to ask
is it possible that i can make a top level module in vhdl while the lower level module is in schematic?
if so can anyone guide me please?
if not possible than should i go for vhdl conversion of schematics?
