Visitor yiz516
HELP, error when launching MicroBlaze application in sdk
I just try to run a MicroBlaze example  in K-7 board, using vivado 2014.4
And I got an error " MicroBlaze is under RESET. Check if the Reset input to MicroBlaze and its Bus Interfaces are connected properly UNABLE to STOP MicroBlaze"
I already connected differential RTL clock with MicroBlaze as figure.
and when launching MicroBlaze application in sdk
i got an error shown below:
so much Thanks!
Tags (2)
Visitor yiz516
Re: HELP, error when launching MicroBlaze application in sdk
problem solved ,
turn out the reason is the RTL reset signal keep activating...
disable the reset signal before run the software...
Teacher muzaffer
verify the polarity of external reset pin with respect to clk_wiz_1.resetn and rst_clk_wiz_1_100.ext_reset_in ports. Are you sure they are all the same polarity?
Visitor yiz516
yes,  these reset signals are all active high...
I succeed in running this example once yesterday,  then I modified something it failed again.
However I can't remember what i have modified, it drives me crazy..
Teacher muzaffer
it's unlikely that clk_wiz_1.resetn is active high.
Visitor yiz516
Hi, muzaffer,
I'm so sorry, clk_wiz_1.resetn in this figure isn't active high indeed,
But I have tried with clk_wiz_1.reset (active high) , it also doesn't work, got the same error.
Visitor yiz516
eh..  not the same error,
It says " MicroBlaze is not being clocked. Check if the Clock input to MicroBlaze and its Bus Interfaces are connected properly"
I think the problem may be relate to clock pin....
Visitor yiz516
problem solved ,
