Visitor williams.a
HSI/HSM: Saving MSS changes
Hi all,
In SDK 2014.4, is there a Tcl command to save changes to the MSS in XSDK batch mode (hsi/hsm)?
I am trying to change the driver assigned to a core, and I can open the sw_design, add my repo, and assign the new driver via the NAME property on a driver object, but I can't figure out how to save the changes back to system.mss. Neither hsi::generate_target nor hsi::close_sw_design do the trick.
Thanks!
Scholar stephenm
Re: HSI/HSM: Saving MSS changes
This should be possible with the flow similar to below:
open_hw_design design.hdf (or design.xml)
set sw_design_1 [create_sw_design sw_1 -proc ps7_cortexa9_0 -os standalone]
add_library xilffs
add_library xilskey
generate_bsp -sw $sw_design_1 -dir xilinx_bsp –compile
Visitor williams.a
Thanks for the response.
Unfortunately, that does not have the intended effect. system.mss is not an output file of the generate_bsp command. generate_bsp (like generate_target) outputs the files that would be generated from system.mss.
More generally, I would like to be able to save the output from a batch script to the project files (so the GUI can reflect the results of that run). It seems like the Tcl and Eclipse paths don't really work together. Changes to user repo paths or object properties do not persist across sessions, either.
