HSI error : invalid command name "hsi::utils::get_rp_rm_for_drv"
Hi all!
I am trying to generate device tree (from hsi command line, from SW SDK or from Vivado TCL console) but I always get following error:
This appends with both custom platform and base Zynq example project.
For information, I am using Vivado v2016.2 (64-bit) / Xilinx SDK Release Version: 2016.2
Complete error message is at this post bottom.
Any help would be much appreciated!
Nicolas.
Complete error message:
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::generate : invalid command name "hsi::utils::get_rp_rm_for_drv"
while executing
"hsi::utils::get_rp_rm_for_drv $drv_handle"
(procedure "set_drv_def_dts" line 14)
invoked from within
"set_drv_def_dts $drv_handle"
(procedure "gen_peripheral_nodes" line 54)
invoked from within
"gen_peripheral_nodes $drv_handle "create_node_only""
("foreach" body line 3)
invoked from within
"foreach drv_handle [get_drivers] {
# generate the default properties
gen_r..."
(procedure "::sw_device_tree::generate" line 3)
invoked from within
"::sw_device_tree::generate device_tree"
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
ERROR: [Common 17-39] 'hsi::generate_target' failed due to earlier errors.
Thanks for your aswer.
Where can I find .xsa file? Is the .hdf file equivalent?
Yes, the HDF is the equivalent.
Following steps defined in the blog you sent me above (i.e. using xsct shell), device tree is generated without error.
Thanks!
