Visitor rkndaiict
Having problem in Build All User Applications.....
    I m having the following problem in creating WebServer on Spartan3E in Build All User Applications..
    /cygdrive/d/rahul/web_server_12/microblaze_0/libsrc/lwip_v3_00_a/src/contrib/ports/xilinx/netif/xemacliteif.c:416: undefined reference to `enable_interrupt'
    collect2: ld returned 1 exit status
    make: *** [Web_Server/executable.elf] Error 1
I have connected all libraries -llwip4 and -lxilkernel. this problem occurs during Build All User Applications. I m not getting why this is happening???Please help me out...
Re: Having problem in Build All User Applications.....
Hello.
If you can paste your MHS file here for reference it will convinient to debug.
Best of luck.
Unlimited in my Limits.
Visitor rkndaiict
Fine Sire,
# Created by Base System Builder Wizard for Xilinx EDK 10.1 Build EDK_K.15
# Fri Jul 10 01:16:18 2009
# Target Board:  Xilinx Spartan-3E Starter Board Rev D
# Family:    spartan3e
# Device:    XC3S500e
# Package:   FG320
# Speed Grade:  -4
# Processor: microblaze_0
# System clock frequency: 50.00 MHz
# On Chip Memory :   8 KB
# Total Off Chip Memory :  64 MB
# - DDR_SDRAM =  64 MB
 PARAMETER VERSION = 2.1.0
 PORT fpga_0_RS232_DCE_RX_pin = fpga_0_RS232_DCE_RX, DIR = I
 PORT fpga_0_RS232_DCE_TX_pin = fpga_0_RS232_DCE_TX, DIR = O
 PORT fpga_0_LEDs_8Bit_GPIO_d_out_pin = fpga_0_LEDs_8Bit_GPIO_d_out, DIR = O, VEC = [0:7]
 PORT fpga_0_DIP_Switches_4Bit_GPIO_in_pin = fpga_0_DIP_Switches_4Bit_GPIO_in, DIR = I, VEC = [0:3]
 PORT fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O, DIR = IO
 PORT fpga_0_DDR_SDRAM_DDR_Clk_pin = fpga_0_DDR_SDRAM_DDR_Clk, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_Clk_n_pin = fpga_0_DDR_SDRAM_DDR_Clk_n, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_Addr_pin = fpga_0_DDR_SDRAM_DDR_Addr, DIR = O, VEC = [12:0]
 PORT fpga_0_DDR_SDRAM_DDR_BankAddr_pin = fpga_0_DDR_SDRAM_DDR_BankAddr, DIR = O, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_DDR_CAS_n_pin = fpga_0_DDR_SDRAM_DDR_CAS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_CE_pin = fpga_0_DDR_SDRAM_DDR_CE, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_CS_n_pin = fpga_0_DDR_SDRAM_DDR_CS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_RAS_n_pin = fpga_0_DDR_SDRAM_DDR_RAS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_WE_n_pin = fpga_0_DDR_SDRAM_DDR_WE_n, DIR = O
 PORT fpga_0_DDR_SDRAM_DDR_DM_pin = fpga_0_DDR_SDRAM_DDR_DM, DIR = O, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_DDR_DQS = fpga_0_DDR_SDRAM_DDR_DQS, DIR = IO, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_DDR_DQ = fpga_0_DDR_SDRAM_DDR_DQ, DIR = IO, VEC = [15:0]
 PORT fpga_0_Ethernet_MAC_PHY_tx_clk_pin = fpga_0_Ethernet_MAC_PHY_tx_clk, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_rx_clk_pin = fpga_0_Ethernet_MAC_PHY_rx_clk, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_crs_pin = fpga_0_Ethernet_MAC_PHY_crs, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_dv_pin = fpga_0_Ethernet_MAC_PHY_dv, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_rx_data_pin = fpga_0_Ethernet_MAC_PHY_rx_data, DIR = I, VEC = [3:0]
 PORT fpga_0_Ethernet_MAC_PHY_col_pin = fpga_0_Ethernet_MAC_PHY_col, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_rx_er_pin = fpga_0_Ethernet_MAC_PHY_rx_er, DIR = I
 PORT fpga_0_Ethernet_MAC_PHY_tx_en_pin = fpga_0_Ethernet_MAC_PHY_tx_en, DIR = O
 PORT fpga_0_Ethernet_MAC_PHY_tx_data_pin = fpga_0_Ethernet_MAC_PHY_tx_data, DIR = O, VEC = [3:0]
 PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 50000000
 PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 1, SIGIS = RST
BEGIN microblaze
 PARAMETER INSTANCE = microblaze_0
 PARAMETER C_INTERCONNECT = 1
 PARAMETER HW_VER = 7.10.a
 PARAMETER C_DEBUG_ENABLED = 1
 PARAMETER C_AREA_OPTIMIZED = 1
 BUS_INTERFACE DLMB = dlmb
 BUS_INTERFACE ILMB = ilmb
 BUS_INTERFACE DPLB = mb_plb
 BUS_INTERFACE IPLB = mb_plb
 BUS_INTERFACE DEBUG = microblaze_0_dbg
 PORT MB_RESET = mb_reset
 PORT Interrupt = Interrupt
END
BEGIN plb_v46
 PARAMETER INSTANCE = mb_plb
 PARAMETER HW_VER = 1.02.a
 PORT PLB_Clk = sys_clk_s
 PORT SYS_Rst = sys_bus_reset
END
BEGIN lmb_v10
 PARAMETER INSTANCE = ilmb
 PARAMETER HW_VER = 1.00.a
 PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
 PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = dlmb_cntlr
 PARAMETER HW_VER = 2.10.a
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x00001fff
 BUS_INTERFACE SLMB = dlmb
 BUS_INTERFACE BRAM_PORT = dlmb_port
END
 PARAMETER INSTANCE = ilmb_cntlr
 BUS_INTERFACE SLMB = ilmb
 BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
 PARAMETER INSTANCE = lmb_bram
 BUS_INTERFACE PORTA = ilmb_port
 BUS_INTERFACE PORTB = dlmb_port
END
BEGIN xps_uartlite
 PARAMETER INSTANCE = RS232_DCE
 PARAMETER C_BAUDRATE = 9600
 PARAMETER C_DATA_BITS = 8
 PARAMETER C_ODD_PARITY = 0
 PARAMETER C_USE_PARITY = 0
 PARAMETER C_SPLB_CLK_FREQ_HZ = 50000000
 PARAMETER C_BASEADDR = 0x84000000
 PARAMETER C_HIGHADDR = 0x8400ffff
 BUS_INTERFACE SPLB = mb_plb
 PORT RX = fpga_0_RS232_DCE_RX
 PORT TX = fpga_0_RS232_DCE_TX
END
BEGIN xps_gpio
 PARAMETER INSTANCE = LEDs_8Bit
 PARAMETER C_GPIO_WIDTH = 8
 PARAMETER C_IS_DUAL = 0
 PARAMETER C_IS_BIDIR = 0
 PARAMETER C_ALL_INPUTS = 0
 PARAMETER C_BASEADDR = 0x81400000
 PARAMETER C_HIGHADDR = 0x8140ffff
 PORT GPIO_d_out = fpga_0_LEDs_8Bit_GPIO_d_out
END
BEGIN xps_gpio
 PARAMETER INSTANCE = DIP_Switches_4Bit
 PARAMETER C_GPIO_WIDTH = 4
 PARAMETER C_ALL_INPUTS = 1
 PARAMETER C_BASEADDR = 0x81420000
 PARAMETER C_HIGHADDR = 0x8142ffff
 PORT GPIO_in = fpga_0_DIP_Switches_4Bit_GPIO_in
END
BEGIN mpmc
 PARAMETER INSTANCE = DDR_SDRAM
 PARAMETER HW_VER = 4.00.a
 PARAMETER C_NUM_PORTS = 1
 PARAMETER C_MEM_PARTNO = MT46V32M16-6
 PARAMETER C_SPECIAL_BOARD = S3E_STKIT
 PARAMETER C_MEM_BANKADDR_WIDTH = 2
 PARAMETER C_MEM_DATA_WIDTH = 16
 PARAMETER C_MEM_DQS_WIDTH = 2
 PARAMETER C_MEM_DM_WIDTH = 2
 PARAMETER C_MEM_TYPE = DDR
 PARAMETER C_PIM0_BASETYPE = 2
 PARAMETER C_MPMC_CLK0_PERIOD_PS = 10000
 PARAMETER C_SPLB0_NATIVE_DWIDTH = 32
 PARAMETER C_MPMC_BASEADDR = 0x8c000000
 PARAMETER C_MPMC_HIGHADDR = 0x8fffffff
 BUS_INTERFACE SPLB0 = mb_plb
 PORT DDR_Clk = fpga_0_DDR_SDRAM_DDR_Clk
 PORT DDR_Clk_n = fpga_0_DDR_SDRAM_DDR_Clk_n
 PORT DDR_Addr = fpga_0_DDR_SDRAM_DDR_Addr
 PORT DDR_BankAddr = fpga_0_DDR_SDRAM_DDR_BankAddr
 PORT DDR_CAS_n = fpga_0_DDR_SDRAM_DDR_CAS_n
 PORT DDR_CE = fpga_0_DDR_SDRAM_DDR_CE
 PORT DDR_CS_n = fpga_0_DDR_SDRAM_DDR_CS_n
 PORT DDR_RAS_n = fpga_0_DDR_SDRAM_DDR_RAS_n
 PORT DDR_WE_n = fpga_0_DDR_SDRAM_DDR_WE_n
 PORT DDR_DM = fpga_0_DDR_SDRAM_DDR_DM
 PORT DDR_DQS = fpga_0_DDR_SDRAM_DDR_DQS
 PORT DDR_DQ = fpga_0_DDR_SDRAM_DDR_DQ
 PORT DDR_DQS_Div_O = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O
 PORT DDR_DQS_Div_I = fpga_0_DDR_SDRAM_DDR_DQS_Div_I_DDR_SDRAM_DDR_DQS_Div_O
 PORT MPMC_Clk0 = DDR_SDRAM_mpmc_clk_s
 PORT MPMC_Clk90 = DDR_SDRAM_mpmc_clk_90_s
 PORT MPMC_Rst = sys_periph_reset
END
BEGIN xps_ethernetlite
 PARAMETER INSTANCE = Ethernet_MAC
 PARAMETER HW_VER = 2.00.a
 PARAMETER C_SPLB_CLK_PERIOD_PS = 20000
 PARAMETER C_BASEADDR = 0x81000000
 PARAMETER C_HIGHADDR = 0x8100ffff
 PORT PHY_tx_clk = fpga_0_Ethernet_MAC_PHY_tx_clk
 PORT PHY_rx_clk = fpga_0_Ethernet_MAC_PHY_rx_clk
 PORT PHY_crs = fpga_0_Ethernet_MAC_PHY_crs
 PORT PHY_dv = fpga_0_Ethernet_MAC_PHY_dv
 PORT PHY_rx_data = fpga_0_Ethernet_MAC_PHY_rx_data
 PORT PHY_col = fpga_0_Ethernet_MAC_PHY_col
 PORT PHY_rx_er = fpga_0_Ethernet_MAC_PHY_rx_er
 PORT PHY_tx_en = fpga_0_Ethernet_MAC_PHY_tx_en
 PORT PHY_tx_data = fpga_0_Ethernet_MAC_PHY_tx_data
 PORT IP2INTC_Irpt = Ethernet_MAC_IP2INTC_Irpt
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER C_EXT_RESET_HIGH = 1
 PARAMETER C_CLKIN_FREQ = 50000000
 PARAMETER C_CLKOUT0_FREQ = 50000000
 PARAMETER C_CLKOUT0_BUF = TRUE
 PARAMETER C_CLKOUT0_PHASE = 0
 PARAMETER C_CLKOUT0_GROUP = NONE
 PARAMETER C_CLKOUT1_FREQ = 100000000
 PARAMETER C_CLKOUT1_BUF = TRUE
 PARAMETER C_CLKOUT1_PHASE = 0
 PARAMETER C_CLKOUT1_GROUP = DCM0
 PARAMETER C_CLKOUT2_FREQ = 100000000
 PARAMETER C_CLKOUT2_BUF = TRUE
 PARAMETER C_CLKOUT2_PHASE = 90
 PARAMETER C_CLKOUT2_GROUP = DCM0
 PORT CLKOUT0 = sys_clk_s
 PORT CLKOUT1 = DDR_SDRAM_mpmc_clk_s
 PORT CLKOUT2 = DDR_SDRAM_mpmc_clk_90_s
 PORT CLKIN = dcm_clk_s
 PORT LOCKED = Dcm_all_locked
 PORT RST = net_gnd
END
BEGIN mdm
 PARAMETER INSTANCE = debug_module
 PARAMETER HW_VER = 1.00.b
 PARAMETER C_MB_DBG_PORTS = 1
 PARAMETER C_USE_UART = 1
 PARAMETER C_UART_WIDTH = 8
 PARAMETER C_BASEADDR = 0x84400000
 PARAMETER C_HIGHADDR = 0x8440ffff
 BUS_INTERFACE MBDEBUG_0 = microblaze_0_dbg
 PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PORT Slowest_sync_clk = sys_clk_s
 PORT Dcm_locked = Dcm_all_locked
 PORT Ext_Reset_In = sys_rst_s
 PORT MB_Reset = mb_reset
 PORT Bus_Struct_Reset = sys_bus_reset
 PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
 PORT Peripheral_Reset = sys_periph_reset
END
BEGIN xps_intc
 PARAMETER INSTANCE = xps_intc_0
 PARAMETER C_BASEADDR = 0x81800000
 PARAMETER C_HIGHADDR = 0x8180ffff
 PORT Irq = Interrupt
 PORT Intr = Ethernet_MAC_IP2INTC_Irpt
END
BEGIN xps_timer
 PARAMETER INSTANCE = xps_timer_1
 PARAMETER C_BASEADDR = 0x83c00000
 PARAMETER C_HIGHADDR = 0x83c0ffff
 PORT Interrupt = xps_timer_1_Interrupt
END
Please help me out....
Thnx
Visitor rkndaiict
hay buddy i hav got d solution of my problem...If anyone having same problem please mail me or post d query......
Hello.
Clearly its visible in your MHS file that xps_timer interrupt you have not mapped in xps_intc.
Good that you got the solution. Is it the same thing or something else?
Best of luck.
