Hello World not appearing on ZCU111
I am trying the Zynq Ultrascale+ MPSoC Embedded Tutorial on ZCU111. I did everything the manual says for running Hello World Program. but at the end, even after waiting for 15 minutes or more, Hello World is not appearing on the terminal. What could be the problem? The snaps are below.
RunConfigs.PNGTerminal Remains EmptyTerminal Remains Empty
Hi @ksram1988
Could you try a different COM port? It sounds like possibly you have the wrong one selected.
Hi @ksram1988
If any of the previous information helped to find a resolution, please mark the helpful post as an accepted solution, for others to find. Also, if you found a solution on your own, explaining the solution and marking that as an accepted solution will help others who face the same issue.
It seems that the port you selected is not the correct one.
If it still doesn't work check your file, close and relaunch.
W.
