Help -- Not able to view program Output on the SDK Console.
I am trying out EDK/SDK for the first time after checking some tutorials. I build a default microblaze project on ML605 using XPS/ SDK 13.3
Then, export the bitsteram to SDK, and create a Helloworld C project and program the FPGA with download.bit created by the SDK ( I think now the bitstream has the required HW and SW part for running SW programs, according to the tutorial).
But when i execute the project file on the HW, i do not see any output on the Console. Initially i used to get
Process STDIO not connected to console.If you'd like to see UART output in this console, please modify STDIO settings in the Run/Debug configuration.
Later I Rightclick current project --> properties -->  Run/Debug Settings and create a new property . Under STDIO Connections ---> Check STDIO to console and select correct baud rate and click OK
(However, the check box "connect process input & output to a terminal" on the main tab, remains greyed out)
But still i dont see any output on the Console window on the SDK when i execute the program. Could someone tell me what am I missing here ?
Thank you,
Venkat.
try to see the out put in hyperterminal of ur pc via rs232 port.otherwise u can take help of this
http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_1/SDK_Doc/tasks/sdk_t_program_io.htm
i am unable to find this option connect process input & output to a terminal in my sdk the version is 2014.3
Hi Annu_shah
This is an old post referring to an older version of SDK. Since you are using 2014.3, you have to set this option by referring to the following snapshot.
--Hem
Hi all,
      I am trying to set up a Technical Refernce Design - Ethernet packet Redirection on a ZC702 board .
      I am using ISE 14.6 instead of 14.5 as suggested by the TRD set up instructions.
      I am getting one of the following errors:
Error 1
Error 2
Blank on the console of SDK
Error 3
If I use JTAG UART
Error opening JTAG UART @ localhost:-1
I have read all the posts and tried everything I could . This is a refernce design and expected it to work.
Any pointers on what needs to be fixed ??
Thank you ,
lasur
this is also the errors that I got. Can any one help us please :)
hi,
can you use a hyperterminal from Windows/putty to direct the stdin/stdout?
--hs
Hi Mouna_zribi,
     I tried what htsvn suggested but didn't work for me . As stated in my post, i was working towards a Xilinx TRD work on my board. The ISE versions and the design files were not compatible.
    I finally got updated design files and moved to vivado flow and the design started working.
    Please analyze the root cause if what htsvn suggested doesn't work.
Thank you,
