Participant sjg69
Help: SDK functions returning bogus values
So I have a virtual filesystem in development which will eventually have multiple different types of driver, at the moment I'm just trying to get a memory-based one to work, to have something to use as a model for the other ones. Here's the fopen() code:
.. with the debugger stopped prior to calling into the code. When it jumps into the code ...
... and has run through the VFS fopen function for the memory-based tmpfs, the variable 'ret' (of type FILE*) is:
... note the address at the bottom. This is a valid address and we're all happy. On return from fopen() though, (so when I step to the next line in the first image, line 754) the address for 'fp' is different from what 'ret' returned...
Any ideas ? I'm a bit lost at this point :(
For what it's worth, this code was all working on an STM32F4 prior to being ported to the Zynq ARM chip, so I'm reasonably sure the logic is ok.
Participant sjg69
Re: Help: SDK functions returning bogus values
Ok, so it seems my problems were being caused by the call to 'taskStats' that you can see in the first image, which was corrupting the stack. I'd put that in to try and make sure my stack was ok (it was, I had 62k left) and not taken it out again. Somehow that call was messing up the stack because when I remove it, the function-returned values are all ok again. taskStats was pretty small though...
static void taskStats(void)
	char buf[128];
	vTaskList(buf);
	printf("%s", buf);
... so maybe the problem has just gone into hiding by having a function call removed... I guess I'll find out...
