Maikkk
Hi!How to write data into a txt in SDK?
Hi!
I have an unsigned char[76800] variable which I would like to save its value into a txt or something to make some processing afterwards in matlab.
How can I save it? Thanks!
stephenm
stephenm
marcb
Hi @Maikkk
If any of the previous information helped to find a resolution, please mark the helpful post as an accepted solution, for others to find.
