aichamb
HlsFir_left' undeclared (first use in this function)
hello , when i'm trying to use a filter_or_bypass_input in eclipse SDK  i have an error and i tryed o fix it but i can't  :( , i need some help to fix it
Description	Resource	Path	Location	Type
'HlsFir_left' undeclared (first use in this function)	helloworld.c	/smo_linear_test/src	line 117	C/C++ Problem
#include <stdio.h>
#include <xil_io.h>
#include <sleep.h>
#include "xiicps.h"
#include <xil_printf.h>
#include <xparameters.h>
#include "xsynth_top.h"
#include "xuartps.h"
#include "xscutimer.h"
#include "xscugic.h"
//I2C Serial Clock frequency in Hertz
#define IIC_SCLK_RATE			400000
unsigned char IicConfig(unsigned int DeviceIdPS);
XIicPs Iic;
typedef short		Xint16;
typedef long		Xint32;
// HLS FIR HW instance
XSynth_top synth_linear;
//Interrupt Controller Instance
XScuGic ScuGic;
//Global variables used by ISR
int ResultAvail;
int hls_synth_init(XSynth_top *hls_synth_top)
   XSynth_top_Config *cfgPtr;
   int status;
   cfgPtr = XSynth_top_LookupConfig(XPAR_SYNTH_TOP_0_DEVICE_ID);
   if (!cfgPtr) {
      print("ERROR: Lookup of Synth_top failed.\n\r");
      return XST_FAILURE;
   status = XSynth_top_CfgInitialize(hls_synth_top, cfgPtr);
   if (status != XST_SUCCESS) {
      print("ERROR: Could not initialize left FIR.\n\r");
      return XST_FAILURE;
   return status;
void hls_synth_top_isr(void *InstancePtr)
	   XSynth_top *pAccelerator = (XSynth_top *)InstancePtr;
	   // clear the local interrupt
	   XSynth_top_InterruptClear(pAccelerator,1);
	   ResultAvail = 1;
int setup_interrupt()
	   //This functions sets up the interrupt on the ARM
	   int result;
	   XScuGic_Config *pCfg = XScuGic_LookupConfig(XPAR_SCUGIC_0_DEVICE_ID);
	   if (pCfg == NULL){
	      print("Interrupt Configuration Lookup Failed\n\r");
	      return XST_FAILURE;
	   result = XScuGic_CfgInitialize(&ScuGic,pCfg,pCfg->CpuBaseAddress);
	   if(result != XST_SUCCESS){
	      return result;
	   // self test
	   result = XScuGic_SelfTest(&ScuGic);
	      return result;
	   // Initialize the exception handler
	   Xil_ExceptionInit();
	   // Register the exception handler
	   Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,(Xil_ExceptionHandler)XScuGic_InterruptHandler,&ScuGic);
	   //Enable the exception handler
	   Xil_ExceptionEnable();
	   // Connect the Synth_top_0 to the exception table
	   result = XScuGic_Connect(&ScuGic,XPAR_FABRIC_SYNTH_TOP_0_INTERRUPT_INTR,(Xil_InterruptHandler)hls_synth_top_isr,&synth_linear);
	      return result;
	   // Enable the Left FIR ISR
	   XScuGic_Enable(&ScuGic, XPAR_FABRIC_SYNTH_TOP_0_INTERRUPT_INTR);
	   return XST_SUCCESS;
void filter_or_bypass_input(void)
	unsigned long u32DataL, u32DataR;
	unsigned long u32Temp;
	int sw_check;
	while (1)
		do //wait for RX data to become available
			u32Temp = Xil_In32(I2S_STATUS_REG);
		} while ( u32Temp == 0);
		Xil_Out32(I2S_STATUS_REG, 0x00000001); //Clear data rdy bit
		u32DataL = Xil_In32(I2S_DATA_RX_L_REG);
		u32DataR = Xil_In32(I2S_DATA_RX_R_REG);
		sw_check = Xil_In32(XPAR_AXI_GPIO_0_BASEADDR+8);
		if(sw_check & 01) // SW0=1 then pass the sample through the filter
			// send samples after shifting least significant 8 bits as the filter
			// requires 16 bit input sample
			XFir_Set_x(&HlsFir_left, u32DataL >> 8);
			XFir_Set_x(&HlsFir_right, u32DataR >> 8);
			// Clear done flags
			ResultAvail HlsFir_left = 0;
			ResultAvailHlsFir_right = 0;
			// issue start
			XFir_Start(&HlsFir_left);
			XFir_Start(&HlsFir_right);
			// wait for done interrupt on each channel and then read the corresponding output sample
		    while(!ResultAvailHlsFir_left);
		    u32DataL = XFir_Get_y(&HlsFir_left);
		    while(!ResultAvailHlsFir_right);
			u32DataR = XFir_Get_y(&HlsFir_right);
			// shift left by 8 bits as output sample is 16 bit whereas CODEC requires 24 bits
			u32DataL = u32DataL << 8;
			u32DataR = u32DataR << 8;
		Xil_Out32(I2S_DATA_TX_L_REG, u32DataL);
		Xil_Out32(I2S_DATA_TX_R_REG, u32DataR);
int main(void)
	int status;
	//Configure the IIC data structure
	IicConfig(XPAR_XIICPS_0_DEVICE_ID);
	// Setup the FIR instances
	status=hls_synth_init(&synth_linear);
    if(status != XST_SUCCESS){
	   print("HLS peripheral setup failed\n\r");
	   return(-1);
    //Setup the interrupt
    status = setup_interrupt();
       print("Interrupt setup failed\n\r");
       return(-1);
    // Enable Global and instance interrupts
    XSynth_top_InterruptEnable(&synth_linear,1);
    XSynth_top_InterruptGlobalEnable(&synth_linear);
	ResultAvail = 0;
	filter_or_bypass_input(); // check SW0 in the function.  If 1 then filter otherwise bypasss
	return 0;
	XIicPs_Config *Config;
	int Status;
	//Initialize the IIC driver so that it's ready to use
	//Look up the configuration in the config table, then initialize it.
	Config = XIicPs_LookupConfig(DeviceIdPS);
	if(NULL == Config) {
		return XST_FAILURE;
	Status = XIicPs_CfgInitialize(&Iic, Config, Config->BaseAddress);
	if(Status != XST_SUCCESS) {
		return XST_FAILURE;
	//Set the IIC serial clock rate.
	XIicPs_SetSClk(&Iic, IIC_SCLK_RATE);
	return XST_SUCCESS;
ibaie
Hi @aichamb,
In the first error code snaphot is pointing that "HlsFir_left" is not declared anywere and actually in the code there is no point where this variable is declared, so expected output.
In the SDK GUI screenshot it seemst that you have much more issues with more undeclared symbols, so don't know from where you took that code but you are missing headers somewhere...
Ibai
aichamb
thank you , how can i fix it
ibaie
Hi aichamb,
Basically you need to find the header files and source files for each of those undeclared function/variables/symbols and add to your project as source/header files.
Ibai
