Visitor vidhya_93
How To change the DDR Execution Address Location in FSBL User Code
Hi Community Users,
I am Working on Zynq 7000 Soc(Baremetal OS). how to change the DDR  Load+Exec Address Location in FSBL User Code.
For Example:
DDR Base Address = 0x00100000
i want to change the Load Address into 0x00400000(DDR Memory) and Execute my Application from this point.How to do this?
thanks in advance...
Re: How To change the DDR Execution Address Location in FSBL User Code
Hi @vidhya_93 ,
Please open the linker script file in your application and change the DDR base address and size based on where you want to load your application. (base address is the start address where you want to load your application).
Please check below image once:
Best Regards,
Srikanth
Visitor vidhya_93
Thankyou For your replay.
Exactly my need is i have 2 Applications
1)app1.elf
2)app2.elf
By using app1.elf+.bit+fsbl.elf i created Boot.bin file and i loaded into Qspi Flash. I know that,BootROM Code load the fsbl into OCM memory.then FSBL load the Bitstream and Application(load into DDR).
My Application1 (app1.elf) is for waiting for app2.elf via Ethernet (TFTP Protocol). Now,My application(app1.elf) is Running in DDR at 0x100000.
int main()
while(1)
//waiting for data//
if(data_came)
break;
/*load the app2.elf into Ext Parellel NOR flash Memory(not in QSPI)*/
/*read the app2.elf from Ext Parellel NOR Flash memory and load into DDR at 0x400000 .*/
/*and execute the app2.elf */
this is possible or not?
Thanks in advance..
