How do I make VC++ 2012 talk to ZC702 via COM port?
I am able to debug with SDK running modules I exported from Vivado block builder. And I am able to send commands through and read back with printf via the SDK Terminal.
Now I wish to have VC++ to communicate to the target so I can dump data to the target CPU/FPGA for processing.
Is the codes below correct?
// hls_macc.cpp : Defines the entry point for the console application.
#include "stdafx.h"
// opty.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <atlstr.h>
#include <windows.h>
class opty
public:
	bool WriteComPort(CString PortSpecifier,CString data)
		int ss=0;
		DCB dcb;
		DWORD byteswritten;
		HANDLE hPort = CreateFile(
			PortSpecifier,
			GENERIC_WRITE,
			0,
			NULL,
			OPEN_EXISTING,
			0,
			NULL
		Sleep(60);
		if (!GetCommState(hPort,&dcb))
		return false;
		dcb.BaudRate = CBR_115200; //9600 Baud
		dcb.ByteSize = 8; //8 data bits
		dcb.Parity = NOPARITY; //no parity
		dcb.StopBits = ONESTOPBIT; //1 stop
		if (!SetCommState(hPort,&dcb))
			return false;
		//int i=0;
		Sleep(60);
		//int l = CString.GetLength(data);
		//for(int i=0;i<l;i++)
		bool retVal = WriteFile(hPort,data,data.GetLength(),&byteswritten,NULL);
		Sleep(60);
		printf("\nBytes written: %d\n",byteswritten);
		CloseHandle(hPort); //close the handle
		return retVal;
int ReadByte(CString PortSpecifier)
	DCB dcb;
	int retVal;
	BYTE Byte;
	DWORD dwBytesTransferred;
	DWORD dwCommModemStatus;
		PortSpecifier,
		GENERIC_READ,
		0,
		NULL,
		OPEN_EXISTING,
		0,
		NULL
	Sleep(60);
		return 0x100;
		return 0x100;
	Sleep(60);
	SetCommMask (hPort, EV_RXCHAR | EV_ERR); //receive character event
	Sleep(60);
	WaitCommEvent (hPort, &dwCommModemStatus, 0); //wait for character
	Sleep(60);
	if (dwCommModemStatus & EV_RXCHAR)
		ReadFile (hPort, &Byte, 1, &dwBytesTransferred, 0); //read 1
	else if (dwCommModemStatus & EV_ERR)
		retVal = 0x101;
	Sleep(60);
	retVal = Byte;
	CloseHandle(hPort);
	return retVal;
int _tmain(int argc, _TCHAR* argv[])
	int i = 0;
	opty ob1;
	bool t  = ob1.WriteComPort("\\\\.\\COM2","24");  // write a byte
	i = 0;
	while (i<10) {  // Get some of the strings
		int a = ob1.ReadByte("\\\\.\\COM2");  // ARM echo it back with printf("\nReceived character: %d\n\r", a);
		printf("%c", a);
		i++;
	bool t2 = ob1.WriteComPort("\\\\.\\COM2","25");
	printf("\nAny key to continue %d!\n", i);
	return 0;
回复: How do I make VC++ 2012 talk to ZC702 via COM port?
My ARM routine is, an infinite loop which scans a charater, immediately echo it back with printf.
I would start the ZC702, try a few SDK terminal iterations, then disconnect SDK Terminal.
Now I start VC++ 2012 debugger and try to run and connect to the same terminal.
The WaitCommEvent is usually where it times out.
	int i = 0;
	opty ob1;
	i = 0;
	while (i<10000) {  // Get some of the strings
		printf("%c", a);
		i++;
	return 0;
