mantise1
How do I make it work with the IP set in the environment?
Hello
I am using the QSPI boot image built in petalinux 2020.1 version.
I want to set the network ip with the ip address set in the environment in boot mode.
Currently, it does not operate with the IP set in the environment. Operates only with the default ip set in petalinux-config.
