How do I set up SDK to create a Linux image on a Windows machine?
I'm trying to follow the getting started guide for the zc706, and make a linux image to program with SDK.
The early step says I need to obtain the device tree compiler tool, in  order to make UBoot. However, using MinGW to try and make the DTC doesn't work. Where do I get the DTC for a windows machine?
Anonymous
Not applicable
You can download the device tree generator and use this in SDK if you addition as a repo ( search how to add repository)
However, to create Linux image you need to use Linux. You can also explore petalinux
You can evaluate the released images for the zc702 here
http://www.wiki.xilinx.com/Zynq+Releases
