Voyager
Voyager
How do callback functions "accept_callback" and "recv_callback" work in Lwip echo sever?
In LwIP echo sever application,  "accept_callback" and "recv_callback" can be called every time when  a connection is built and data is received.  Both of them are callback functions.
I try to understand hwo they work, so I read the callback function in Wikipedia. However, it still confuses me since the working approach of these two functions differ from the examples in Wikipedia
In the article of Wikipedia, it takes an example for callback in C:
int main() {
    PrintTwoNumbers(&rand);
    PrintTwoNumbers(&overNineThousand);
    PrintTwoNumbers(&meaningOfLife);
    return 0;
rand(), overNineThousand(), and meaningOfLife(), all these three functions are called when the program is excuted. However, in LwIP application, the command: "tcp_accept(pcb, accept_callback)" which is inside the "start_application()", setup the accept_callback. My question arises, why is just setup this function instead of calling it?
Is the difference resulted from property of these two functions "accept_callback" and "recv_callback" ?
Thanks very much.
Voyager
Voyager
Re: How do callback functions "accept_callback" and "recv_callback" work in Lwip echo sever?
Anybody can help?
Voyager
Voyager
Nobody know this?
