arash9k
How do you open a terminal session for an FPGA (other than the first FPGA) in a JTAG chain?
Normally, in order to open a terminal session to the first FPGA in a JTAG chain, I would run these commands in XMD:
connect mb mdm -debugdevice devicenr 1
terminal
 But, now I need to open a terminal to the 2nd FPGA in a JTAG chain, so naturally I tried this:
connect mb mdm -debugdevice devicenr 2
terminal
 but this opens a terminal session to the first FPGA in the chain. I can tell because: 1) it doesn't work 2) when I run the "targets" command I see the following:
XMD% targets
------------------------------------------------ System(0) - Hardware System on FPGA(Device 2) Targets: -------------------------
Target(0) - MicroBlaze(1) Debug Target
------------------------------------------------ System(1) - Hardware System on FPGA(Device 1) Targets: -------------------------
Target(256) - MDM Uart Channel Target
Tags (2)
Anonymous
Not applicable
you need to specify the chain for the terminal aswell, otherwise as you said it will default
arash9k
How do you specify the chain? The "terminal" command doesn't have a chain option as I see in the XMD manual.
Anonymous
Not applicable
will be something like:
connect mdm -debugdevice devicenr 2 -uart
terminal
