aymanhendawy
How much instruction cycles required by Cortex-A53 Neon intrinsic functions execution?
I working on ZCU102 board of ARM Cortex-A53 runing linux image built by petalinux 2018.2, and I was trying to write some Neon intrinsic C codes like adders and multippliers in the code snippet below, but when I profiled the neon intrinsic functions I got unlogic execution cycles of about 600 cycles, which doesn't make sense to me, and I don't know what's wrong with my code or the default compiler?
Refering to this link in section "NEON floating-point instructions timing", I see my output cycles are contradecting what's listing there, also is there a working link listing the whole NEON instructions timing for Cortex- A53.
compiler options added,
-c -fmessage-length=0 -MT"$@" -mcpu=cortex-a53 -march=armv8-a -mno-lint -mdev-no-llvm -O3 -Ofast
void add32fn(void * a, void * b)
       int32x4_t a32, b32, res32;
	a32 = vld1q_s32(( int32_t *) a);
	b32 = vld1q_s32(( int32_t *) b);
	reset(&prof);
	start(&prof);
	res32 = vaddq_s32 (a32, b32);
	stop(&prof);
	volatile uint32_t cycles  = avg_cpu_cycles(&prof);
       //cycles = 600
	vst1q_s32((int32_t *)(res), res32);
void cmplxfloatmul(void * a, void *b)
	float32x4x2_t 	aNeon, bNeon, resNeon;
	float32x4_t 	RXR, RXI;
	aNeon =  vld2q_f32 ((float32_t const *) (a ));
	bNeon =  vld2q_f32 ((float32_t const *) (b ));
	reset(&prof);
	start(&prof);
	RXR  = vmulq_f32 (aNeon.val[0], bNeon.val[0]);			//aR*bR
	stop(&prof);
//cycles are about 600 for this and any of the below functions
	resNeon.val[0]  = vfmsq_f32 (RXR, aNeon.val[1], aNeon.val[1]); 			//aR*bR-aI*bI
	RXI	= vmulq_f32 (aNeon.val[0], bNeon.val[1]);				//aR*bI
	resNeon.val[1] = vfmaq_f32 (RXI, bNeon.val[1], aNeon.val[0]); 			//aR*bI+aI*bR
	vst2q_f32((float32_t *)(res + idx), resNeon);
ibaie
Hi @aymanhendawy ,
I've never tried to use NEON Intrinsics on Linux userspace application, so not sure about it's performance so will need to do some testing. From instruction cycle count that is really specific to ARM, but I think there is no public document listing them.
Ibai
aymanhendawy
Kindly any updates in this regards
