How to Handle Multiple Interrupt in Zynq
Hi Folks,
we working with Zynq 7020clg400-2.
We are using interrupts are,
1-> PL-PS GPIO interrupt.
2-> PS GPIO interrupt.
currently, individually working perfect. But when taking into software integration, one interrupt is working another is not working means PS GPIO interrupt is working but PL-PS GPIO interrupt is not working. And here we are not using interrupt priority.
Please suggest us regarding multiple interrupt handling.
Thanks and Best Regards
Vinod Sajjan
Hi @vinod.sajjan
Would be great if you explain a little bit more about your application, I mean is just standalone code or Linux app? Some code snapthot could be useful as well. What does mean not working...
Ibai
Ibai
Hello @ibaie,
We are using standalone application(i.e. Baremetal). As per our code design, if we get an interrupt from Ps gpio- some flag should be set.  If we get an PL_Ps interrupt, other flag should be set.
As per our requirement, Ps Gpio interrupt should be served first and should check for any PL_Ps interrupts.
But the issue is the execution never comes out of Ps Gpio Interrupt handling functions.I have attached my code, please go through it .Please suggest me .
Vinod Sajjan
Hi @vinod.sajjan
Did you debug the code with the SDK debugger? What can you see there?
Ibai
Ibai
Hi @ibaie,
Yes we do debug the code with SDK debugger(Jtag). The execution goes directly to Vector.S file. The other Pl_Ps interrupts are never handled .
Vinod Sajjan
