sxl630828191
How to access SD card through the SDK on Zynq
Hi, everyone
I want to access the SD card on the zed board through the SDK environment .
I find sth called the sd_fatfs, but I can't find the way to download it.
Is there any way else to access the SD card through the SDK environment without operation system.
Thanks for your reply.
SXL
htsvn
SD card access without an operating system is not available at the moment
--HS
ryserp
FSBL has a built-in capability to access the SD card. You can use the FSBL source code as a starting point.
